Subject Topic: Fuses blown? Post ReplyPost New Topic
Frontier1
Posted: Aug 15 2011 at 10:12am | IP Logged Quote Frontier1
I bought my truck used and only one of the two cigarette lighter/
accesory ports on the dashoard worked ad I thought no big deal its
probably just a blown fuse and nothing more. Recently I went on
vacation and my daughter had a portable dvd player plugged into the
one located inside the armrest compartment and it died mid trip. So
when I got home I thought it would be a good time to change out the
fuses on them. I popped the two fuse boxes under the hood and the
one in the glove box and still haven't seemed to be able to locate any
blown fuses. Can anyone tell me exactly what the lower one on the
dash and the arm rest comparment are labled under? I hope its a
simple fix and not a more serious electrical issue
07 Nissan Frontier SE crew cab 4x4
Back to Top View Frontier1's Profile Search for other posts by Frontier1
Posted: Aug 15 2011 at 8:51pm | IP Logged Quote frontierguy
The fuse panel in the glove box area has 2 fuses, 1 is
labeled "power outlet" and the other is labeled "cigar
Lighter". Should be listed in your owners manual. Both are
15 amp fuses.
Frontier1
Posted: Aug 16 2011 at 9:55am | IP Logged Quote Frontier1
Can a fuse be bad even if the link inside isn't blown? Im pretty sure I
checked those and they looked ok but ill double check..thanks!
Posted: Aug 16 2011 at 7:26pm | IP Logged Quote frontierguy
They are so small it is hard to see them. The best way to
check is with a test lite or remove them and check with an
ohm meter or just replace with a known good fuse.
NorthrnManitoba
Canada
Posted: Sep 23 2011 at 7:38am | IP Logged Quote NorthrnManitoba
i own a 07 frontier nismo and i had both of my power outlets die on me while being used as well.  checked the fuses with multimeter and the fuses are fine...   i dunno where to look next?
Back to Top View NorthrnManitoba's Profile Search for other posts by NorthrnManitoba
NorthrnManitoba
Canada
Posted: Oct 03 2011 at 9:27am | IP Logged Quote NorthrnManitoba
frontier guy told me to check the fuse under the hood in the ipdm e/r   i replaced the fuse in there and now everything is woprking again!!! problem solved     thank you to frontierguy!!
Frontier1
Posted: Oct 04 2011 at 7:46am | IP Logged Quote Frontier1
What size is the fuse in there and is it located in the regular boxes
under the hood or in a special location?
NorthrnManitoba
Canada
Posted: Oct 04 2011 at 8:01am | IP Logged Quote NorthrnManitoba
i think it was a 15 amp fuse
i dont know what you mean by regular boxes, but it is in the bigger of the two black boxes, the one with wire harnesses in it.
Frontier1
Posted: Oct 04 2011 at 9:16am | IP Logged Quote Frontier1
Gotcha..thanks alot! Ill have to check that out when I get
home.
NorthrnManitoba
Canada
Posted: Oct 04 2011 at 11:59am | IP Logged Quote NorthrnManitoba
no problem   i hope that fixes your problem!   thank frontierguy not me lol! i just passed the info on
Page of 2 Next >>
