RidemoSleepless Newbie
| Posted: Aug 15 2011 at 8:43pm | IP Logged
So I have a 2000 Nissan Frontier, Desert Runner. It only has 76K miles. Just recently I started noticing a sound when I push in the clutch. It sounds kinda whiny, or like something is spinning loose. A friend of mine listened to it and said it might be the through-out bearing. I don't know what this is, but it didn't stop me from pretending that I did. Any ideas?
| Posted: Aug 15 2011 at 8:48pm | IP Logged
Does it do it every time the clutch is depressed? If so,
most likely it is the throw out bearing.
| Posted: Aug 15 2011 at 10:20pm | IP Logged
Yes it does, and now the pitch is getting lower, it used to be alot higher sounding. I guess this means my truck will be sitting in the driveway till next payday.
