Subject Topic: ’04 - Replacing a Supercharger Post ReplyPost New Topic
jordanc
U.S. - Virginia
Posted: Aug 17 2011 at 9:23am | IP Logged Quote jordanc
Hello all!
I have a 2004 Frontier (V6, Crew cab) with just under 100,000 mi on it, and a bad supercharger that has been through a lot. I’m hoping someone can give me some advice on swapping it out for a new one, and how difficult that might be. I’m not a mechanic, and haven’t worked on my truck much, but I’m pretty handy with lots of other things and I am hoping this is a project I can do myself - because the dealership wants 2300 to fix it.
Here is the background: the supercharger started making a bunch of noise about 3 years ago. I was told by the dealership it was bad and the price they quoted me was 2100. I had a friend who thought rebuilding the supercharger (replacing all the bearing) would be the cheap fix. 600$ in parts later, it appeared to be done. Then he fired up the engine and realized he had forgotten to take a rag out of the intake. Needless to say, it was a mess, and the whole thing had to be taken apart again. End result: it didn’t sound better; it just made a slightly different noise. So I had been driving around for about 30,000 mi with it like this until about a month ago when the noise got worse (like cement in a blender) you cant even hold a conversation next to the truck when its idling. This time the dealership (different one in another part of the state) quoted me 2300.
The part I need appears to be an Eaton, and it looks fairly simple to replace: 6-8 bolts, replace a gasket, maybe hook up a sensor.. Let me know if im totally off on this.
Any comments, suggestions or feedback would be great.
Looking forward to hearing from the Frotier community!
thanks,
- Jordan
Back to Top View jordanc's Profile Search for other posts by jordanc
Posted: Aug 17 2011 at 7:42pm | IP Logged Quote frontierguy
#1 it is a straight forward replacement procedure as you
mention.
#2 Are you certain it is the SC and not the timing belt
rattling(due @ 105K). Try running w/o the drive belt on to
be sure.
#3 are you using hi-octane fuel, if not the system will go
into a fail safe mode creating all kinds of noise.
jordanc
U.S. - Virginia
Posted: Aug 18 2011 at 12:19pm | IP Logged Quote jordanc
Thanks for the feedback frontierguy. Ill be sure to check your #2 point, I hadnt thought of that. I need to check if there is a seperate belt or if it is part of the serpentine.
Also, I always thought hi-octane fuel was more of a suggestion than a requirement, sounds like thats not the case, I hope I havent screwed it permenantly. Ill fill it up with the good stuff tonight and see what kind of difference that makes.
If it helps at all, i found out the engine configuration is a "VG33ER".
Thanks again,
- Jordan
jordanc
U.S. - Virginia
Posted: Aug 22 2011 at 1:25pm | IP Logged Quote jordanc
Update -
After filling up with 93, and putting in some system cleaner, its definitely running better. I took off the supercharger/ac belt and ruled out the timing belt.
Bottom line is this: supercharger is still bad, but not so bad. I think I can hold out for another 30,000 mi before I will need to replace it.
Anyone know what risks might be involved in holding off on replacing SC? If I risk permenant damage, ill get it done tomorrow. If its just a matter of it sounding bad, i can put up with that for a while.
Thanks,
- Jordan
Posted: Aug 22 2011 at 8:01pm | IP Logged Quote frontierguy
Do a search, there is a thread on how to change the oil
although Nissan does not list any maintenance requirements
for the SC. (in fact, the service manual says DO NOT
DISASSEMBLE).
