| Posted: Sep 07 2011 at 11:40pm | IP Logged
Sorry, I realized I posted in the General category and then I thought the technical problems area was more appropriate.
The battery was new and the post connections appeared new or thoroughly cleaned when I purchased the truck. You say look for several ground wires--do you think that a bad ground wire is a possible cause of the problem? The insulation on the battery negative cable to the block appears to be melted about 6 inches from the block. Could that be an indication of a problem?
My diesel mechanic neighbor crawled under the truck to view the starter and saw a cable that is attached to the starter was partially void of insulation. He said he could see bare twisted copper cable. Is that normal or a possible problem?
Again, thank you for any advice you may have.
__________________ skyminamon
