| Posted: Sep 20 2011 at 10:32pm | IP Logged
Clutch chatter is avibration or jerkyness that happens when you let out the clutch peddle to engage the clutch. There could be several causes including diver usage, worn linkage, bad motor mounts, play in the running gear and problems in the bell housing and clutch.
Good luck.. Don S..
