| Posted: Nov 05 2011 at 9:13pm | IP Logged
I'm replacing the wqater pump, radiator hoses and heater hoses on my 98 4 cylinder to fix a series of small coolant leaks at the connections. I was seduced into do this by the potential to save about $800 in labor. I'm learning why the labor was so high!
One of the heater hoses connects to the engine block in an virtually unreachable place tight against the firewall at the tranmission tunnel in the back of the block. Any tricks or tips for getting this clamp and replacing the hose? I can touch the clamp, but can't see it. The only possiblility seems to be taking the right front wheel off, removing the skirting and using a series of extentions (about 2 feet) to reach the clamp bolt. Seems kind of hokey.
Surely sombody has encountered this problem before?!
Thanks!!
