Subject Topic: No clutch pressure Post ReplyPost New Topic
46hand
U.S. - Washington
Posted: Nov 19 2011 at 8:34pm | IP Logged Quote 46hand
I reinstalled my transmission last night, and afterward attempted to bleed the clutch. I have zero pressure, and no return. My roommate says throwout bearing, but does not have a rationale. I don't want to take that sob back out to find out though. Thoughts?\
PS- In hindsight, the extra $600 for R/R would have been worth it. What a nightmare.
'98 Frontier SE KC 4x4 2.4L 5 speed
Back to Top View 46hand's Profile Search for other posts by 46hand
Posted: Nov 19 2011 at 10:51pm | IP Logged Quote lakota
I've never done a Nissan but on an 89 Chevy 350 4x4 I had to pump fluid in at the bottom. We could not get the air out by bleeding at the bottom and filling at the top. I used a pump action type oil squirt can with the proper fluid to fill the line up without air.
Good Luck.. Don S..
Posted: Nov 20 2011 at 8:25pm | IP Logged Quote frontierguy
If memory serves me correct, there is a dampener on the
pass side firewall with a bleeder screw that needs to be
bled. Did the clutch pedal get depressed when everything
was apart by some chance??? The master and slave cylinders
may have failed also. What was the original concern?
