Frontier1 Groupie
| Posted: Dec 08 2011 at 8:35am | IP Logged
Ive noticed the heat in my truck seems to only be hot when I'm moving..
Sitting at lights and idling it seems to go cool.. Not actually cold but
noticeably cooler. My xterra used to do this also. What could cause
this?
__________________ 07 Nissan Frontier SE crew cab 4x4
| Posted: Dec 08 2011 at 6:54pm | IP Logged
Check the coolant level in the over flow tank, also check
for any "oily" scum in there. Possible coolant is getting
into the ATF.
Frontier1 Groupie
| Posted: Dec 09 2011 at 6:11am | IP Logged
You'll have to forgive me I'm not the most knowledgable of car guys
what is ATF? And could this be a major problem? Costly?
davidjbrady Senior Member
| Posted: Dec 09 2011 at 1:27pm | IP Logged
ATF is automatic transmission fluid.
Frontier1 Groupie
| Posted: Dec 09 2011 at 1:59pm | IP Logged
I was thinking that but didnt wanna sound stupid just in case it stood for
something else..lol .My truck is a 6spd manual though
chadecoen Newbie
| Posted: Dec 19 2011 at 9:43pm | IP Logged
Hi, More than likely you have air in the cooling system. When you get to a red light and the truck returns to idle the coolant stops circulating or slows dramatically to the heater core. When you leave the light you step on the gas revving up the engine and begin circulating hot coolant to the core again thus you feel the temp go up. Try just revving the engine in neutral at the next light and see if it heats back up. Prolly just burp the system and see if works. If it fixes but returns soon after, then you have other issues of how the air is entering the cooling system. Good luck
| Posted: Dec 21 2011 at 6:44pm | IP Logged
I have found out when you fill the radiator, put the front of truck on ramps, air will go to the highest point and the bubbles should dissipate, course, this would mean you have to drain and refill.
killingjoke Newbie
| Posted: Dec 27 2011 at 7:50pm | IP Logged
You might have a bad water-pump.Pull off the coolant hose from outlrt of heater core. chek the flow at idle,Should have good flow if not it will be very low.accelerate at a high rpm and if flow is faster and more volume then waterpump is faulty.
droopydawg Newbie
| Posted: Dec 31 2011 at 12:14pm | IP Logged
My wife's Mini Cooper had the same problem. We even explained it to the
dealer and they said that we must be wrong. Later, during a normal fluid
level check that I do, I noticed the coolant level was low. I added just under
about 2 quarts of fresh coolant. That solved the problem.
__________________ Drew Mobley
Lake Forest, Illinoying
05 CC SE 4x4 V6 6spd man.
