Subject Topic: Program new remote Post ReplyPost New Topic
Btpham919
Posted: Jun 07 2013 at 10:09am | IP Logged Quote Btpham919
Have 2002 Nissan Frontier Crew Cab. Lost 1 remote, still have 1 working. Bought new remote with same model and FCC ID.
Followed instruction " insert key into ignition 6 times...etc "
Still cannot get to "harzard lamps will flash = programming mode "
Was told by Nissan technician to bring it in to have them clear all data before programming the new remote.
It's not only the cost but also time to bring it in
Thanks in advance for your help
Back to Top View Btpham919's Profile Search for other posts by Btpham919
Posted: Jun 09 2013 at 8:11pm | IP Logged Quote frontierguy
step #1 lock doors
step #2 insert key in ignition rapidly in and out until
flasher flash
step #3 turn to acc
Step #4 push any button on remote
Step #5 unlock then lock door
Step #6 push any button on next remote
Step #7 unlock door check remotes for proper operation
Btpham919
Posted: Jun 09 2013 at 11:21pm | IP Logged Quote Btpham919
Frontierguy,
Thanks for your response , but I never get passed  step 2.
Was told by Nissan Technician that I heve to get the truck in to have it clear all data on receiving side on the truck for it to accept new data.
Posted: Jun 10 2013 at 7:55pm | IP Logged Quote frontierguy
Did you lock the doors?? The in and out of the key needs to
be done quickly and consistently. There is no clearing of
the data required. They just want your money$$$$$ You may
have a bad sensor that isn't seeing the "lock" signal @ the
lock cylinder.
Btpham919
Posted: Jun 10 2013 at 10:07pm | IP Logged Quote Btpham919
Many thanks
I will try again
