Travis1998 Newbie
Posted: Aug 26 2013 at 9:21am | IP Logged
I have a 98 Frontier with the dreaded A/C issue and I do believe its
the amplifier however everyone I see with a part number is the three
wire. Mine is a two wire, could anyone care to share that with me?
Travis1998 Newbie
Posted: Aug 26 2013 at 9:50am | IP Logged
[IMG]uploads/Travis1998/2013-08-26_094942_cooling_unit.jpeg[/
IMG]
Mine is this style, has a one screw tab on the end of it securing it to
thr box.
Posted: Aug 26 2013 at 7:20pm | IP Logged
your link doesn't work. It does have 3 wires =
green/orange, blue/black, black.
Travis1998 Newbie
Posted: Aug 26 2013 at 10:10pm | IP Logged
This is the one I have, not the standard one I keep seeing that is
getting posted and it does only have two wires.
Posted: Aug 26 2013 at 10:18pm | IP Logged
You might try up-loading the photo in your gallery. Then
you can post it or we can go look at it or I might be able
to post it for you.
I have problems posting images unless I'm using MS
Explorer...
Good luck.. Don S..
Travis1998 Newbie
Posted: Aug 27 2013 at 9:17am | IP Logged
Finally got it to upload!
So does anyone know the part number on this style? 1998 Frontier 4wd.
Thanks for any help!
Posted: Aug 27 2013 at 8:23pm | IP Logged
Have you tried your dealer, they should be able to look it
up by the VIN #.
