rwaterson Newbie
| Posted: May 29 2016 at 12:04pm | IP Logged
After trying to follow up on some advice that I got on
Frontier forums I am getting the impression that there
is no Thermal Control Amplifier on a 2006 Frontier. The
FSM talks about an Intake Sensor; does this perform a
similar function on my 2006 that the TCA does on 1st
generation Frontiers? Or am I strictly looking at an
issue with the IPDM? I have not yet found anything in
the FSM about the IPDM.
I took off the glovebox to check and there were no wires
going into the evaporator box like there seem to be if
there is a TCA in there.
In a nutshell, I am getting no power at the compressor
(magnetic clutch) or at the pressure switch, so this is
not a low R134 problem. I do have power on both sides of
the AC fuse. Could this be an intake sensor problem? Any
ideas for troubleshooting this issue would be greatly
appreciated.
2006 Frontier 4.0 V6
__________________ 2006 Frontier 4WD 4.0 V6
| Posted: May 29 2016 at 12:35pm | IP Logged
Something has to tell the compressor when to run and turn off. I am old school and modern fools spend too much time trying to figure out more ways to involve the computer and make them more expensive... Like $900.00 for one installed in an '04 Sentra in 2008!
But yes fuel injection is nice...
You might try hot wiring the clutch with engine off. It should make a clicking sound.
Sorry I couldn't help.. Don S..
rwaterson Newbie
| Posted: May 29 2016 at 4:24pm | IP Logged
I tried that before... I ran power directly from the
battery to the compressor and the clutch engaged.
