         bmh050570 Newbie
           | Posted: Aug 05 2016 at 10:23am | IP Logged
good day all we have an 2008 frontier that we pulled to speedometer in and now we cannot get it to start. any ideas? does the speedo have to be reprogrammed? any help would be appreciated.
           | Posted: Aug 06 2016 at 6:17pm | IP Logged
You pulled the speedo or ECM??? I'm confused!
         bmh050570 Newbie
           | Posted: Aug 06 2016 at 6:30pm | IP Logged
We pulled the speedometer to
 change a bulb in it and now the
 truck will not crank no power to
 ecm. We have checked all fuses.
 In the process of changing the
 bulb, it got broken so may have a
 broken circuit.
           | Posted: Aug 17 2016 at 6:07pm | IP Logged
Are you sure the speedo is plugged in correctly? Have
 you checked for any blown fuses?
