Mr.Grandpa Newbie
| Posted: Jan 29 2019 at 1:31pm | IP Logged
'07 was not engaging not 4 wheel drive. Code for rr wheel sensor.
Replaced sensor, didn't work. Found a bad wire, repaired it and it still
didn't engage. Have disconnected both rear speed sensors and now
the 4 wheel drive engages! I'm confused!! Help please?
| Posted: Jan 30 2019 at 3:13pm | IP Logged
I can't be of help I'm Old school I manually shift mine.
But It Works.
Hope someone will come with some ideas.
Good Luck.. Don S..
| Posted: Feb 10 2019 at 6:59pm | IP Logged
In most cases, if there is a problem w/ any of the wheel
sensors, 4WD will not work. Never tried disconnecting
them to make it work. The sensor itself may be bad or
there is still a harness issue somewhere.
