Subject Topic: Transmission issues due to fluid leak Post ReplyPost New Topic
oneclickwonder
Canada
Posted: Jun 17 2019 at 9:23pm | IP Logged Quote oneclickwonder
Hey everyone,
So last week my 2008 Frontier LE v6 crew cab (5 speed auto
transmission) started acting funky. At first it was just an intermittent
slight jerk as the truck was downshifting - when I came to a stop or
slowed speed in traffic. It felt less smooth on those automatic
downshifts. In fact, it was so slight and intermittent that I wondered
if I was being overly sensitive. It carried on throughout the week,
not getting any worse until the weekend when it was extremely hot
out. Then I started noticing slippage upon acceleration from a
starting position - Id need to give it more gas and it would slowly
get up to speed instead of being responsive off the line. But again,
this problem was intermittent.
So i brought it to the shop today, whole drive out it was fine. Took it
for a spin with the technician - downshifting problem reemerged.
They pulled the fault codes, did some diagnostics and came back to
me a few hours later with the problem - your radiator is leaking
coolant fluid into the transmission fluid thus contaminating it. This
is getting into your transmission causing problems and possibly
damage. It seems to be a known problem on this vehicle. Your
options are A.) we replace the faulty radiator, the malfunctioning
valve, flush the tranny and reset the computer. Cost - $4grand
(Canadian). Oh, and caveat, we cant guarantee that it will work and
there may be damage that causes tranny failure later but from our
database, its a known fix that has had success. Option B.) Replace
the entire tranny and rad unit. Cost - $7grand.
So head spinning I tell them I'll get back to them. I do some
research and find out that indeed this is a known design flaw
problem with a factory recall and lawsuit attached. Seems failure of
this type is common on this year/model (2005 - 2010) and usually
happens around the 110,000 mile mark. Well, mine is at 108,000
miles. Right on schedule. I call the shop and say - if this is a known
design flaw, and youre replacing with OEM parts, is it not possible
this happens again? He said, well yes - it is possible given the flaw.
Im the second owner of the vehicle. Purchased from a private seller
2 years ago for $12,500. Its a great truck, in good shape otherwise. I
really like it. But 7grand on a 10, almost 11 year old vehicle seems
steep. Especially if it could fail again. Honestly, i dont know what to
do. Try the cheaper rad replacement, tranny flush option and cross
my fingers. Replace the tranny/rad and hope it doesnt fail again for
another 100,000 miles. Or take it to a dealership and say - what will
you give me if i trade it in for a new vehicle?
Have any of you had experience with this problem? What did you
do? Any thoughts / advice would be much appreciated!
r2lihou
Back to Top View oneclickwonder's Profile Search for other posts by oneclickwonder
Rubble
Posted: Jun 17 2019 at 10:13pm | IP Logged Quote Rubble
oneclickwonder wrote:
Hey everyone,
auto
came to a stop or
automatic
that I wondered
extremely hot
acceleration from a
would slowly
line. But again,
was fine. Took it
reemerged.
came back to
is leaking
possibly
vehicle. Your
malfunctioning
$4grand
will work and
but from our
B.) Replace
do some
design flaw
Seems failure of
and usually
108,000
this is a known
not possible
given the flaw.
private seller
shape otherwise. I
vehicle seems
dont know what to
option and cross
fail again for
say - what will
did you
Nissan did an extended warranty for this issue, so 1st
thing in the morning I would call NISSAN CONSUMER
AFFAIR'S AND TELL THE THE WHOLE STORY to see if your
vehicle will fit into the extended warranty and if
Nissan can help you. That's the 1st thing that I
would do.
When you call them,, be prepared to give them the VIN
# and the date of the sale on the Bill of Sale.
It's my understanding that Nissan sent out letter's to
the original owner's of Frontier's that might be
affected by this issue. If you bought your Frontier
from an Authorized Nissan Dealership be sure to tell
Nissan Consumer Affair's that you did. If the Nissan
Dealership didn't divulge this issue if they sold you
the Truck,, then that might help your case more with
Nissan Consumer Affair's. Also if the Original Owner
didn't pass along the Notice from Nissan about this
Issue, then that may also help your case.
Be Nice when you talk with them, it won't help you to
argue with them or to be Disrespectful. Just ask in a
sincere and respectful manner if they can help you.
After you contact Nissan Consumer Affair's then let us
know,, and we can offer more advice after we know what
they will do, Might do, or not do.
At any rate, don't drive the Truck anymore till you
figure out what to do.
PS- Just in case you decide to Trade for a New
Nissan; Since you own a Nissan,, Nissan Consumer
Affair's will give you a VPP Discount on a New Nissan,
which is another reason to talk nice to them,, as they
are the same one's that will issue the VPP # Discount
to you. They gave me one,, which really helped me get
my '13 Frontier. I've recently checked TrueCar.com,,
and Nissan is really giveing some very good deal's on
Nissan Frontier's. From what I've seen even better
deal's now,, than when I purchased back in 2013.
Regards,
Posted: Jul 21 2019 at 7:03pm | IP Logged Quote frontierguy
Depending on the miles, you may have to pay based on pro
rated amount.
   I have replaced many trans and rads w/ no reoccurring
problems. I would go the dealer route, just check and
see if you are responsible for any $$$$ due to miles.
