Subject Topic: 2007 Nissan Frontier Shaft Noise/Vibratio Post ReplyPost New Topic
eddiem98
U.S. - Hawaii
Posted: Oct 18 2026 at 7:00pm | IP Logged Quote eddiem98
Aloha
Im the owner of a 2007 Nissan Frontier Crew 2WD manual
trans.I've been chasing an issue with what I believe is
the drive shaft. The truck has new tires, new brakes and
rotors, new Ebrake shoes, new Struts and Shocks. My
clutch needed to be replaces and since the vibration was
already getting bad due to what we thought it was a
problem with the carrier bearing decided to replace the
clutch (Disk, Pressure plate and bearing) also replaced
the seal on the trans and since we were already there the
shaft was replaced. One may ask why didn't I just replace
the carrier bearing and the answer is because the OEM
shaft was missing a few weights due to corrosion in
Hawaii. So i replaced the drive shaft with a Chinese OEM
part.
The new shaft also vibrates and makes a similar noise
like the one when you have unbalanced tires I can feel
the shaft vibrating via the gear shifter and it is not
noticeble at low speeds (Below 40 MPH) once you are on
5th or 6th gear the noise and vibration start. We checked
the wheel bearings as well and they all seem to be okay.
This truck only has 60K miles and should not be having an
issue with the Drive Shaft but here I am stomped with 2
proffesional mechanics with over 50 years experience.
If anyone has had an issue similar to this one please
chime in.
Mahalo and Aloha from the Islands.
2007 Nissan Frontier Crew Cab 2WD 4.0L engine.
Back to Top View eddiem98's Profile Search for other posts by eddiem98
Rubble
Posted: Oct 18 2026 at 8:45pm | IP Logged Quote Rubble
eddiem98 wrote:
Aloha
part.
chime in.
How About The Universal Joints?
You would need to consult the Nissan manager or His Best
Master Tech to see if the New Drive Shaft Needs to be
Balanced.
eddiem98
U.S. - Hawaii
Posted: Oct 18 2026 at 9:58pm | IP Logged Quote eddiem98
Mahalo for the response, the U Joints and Drive Shaft are
new and the DS is supposed to be balanced. I even asked for
the specs for it, supposedly the balancing is within specs.
It is absolutely possible that the Chinese drive shaft is
not balanced correctly which will explain the issue.
Losing my mind over this one for sure.
Rubble
Posted: Oct 19 2026 at 8:34pm | IP Logged Quote Rubble
Drive Shaft are
I'm thinking that you are going to need to take it to someone that
specializes in this type of stuff. I don't rightly know what that
type of specialized Shop might be though.
Is your Truck Raised, so that there is an increased Angle from
the transmission to The Rear Axle Houseing? Too much Angle
can be too much for the UJoints. I know this can be true,, cause
I've experienced a lot of Vibration with the Driveshaft on my
rotary cutter, when I raise the Hitch just a little bit,, and the
increased Angle will vibrate the Whole Tractor.
I guess that it is possible that the drive shaft is not the correct
length.
Maybe the Carrier Bearing isn't bolted down good,, or maybe
the Bearing has some slop in it, or maybe it is not functioning
like it should and may be binding.
All of the above are purely guesses on my part; That's why I
think You need a professional to take a look at it. A true
professional might spot the problem Straight Away.
A Good body Shop might be able to point you in the right
direction to get the right type Professional to diagnose the
problem correctly.
This Might also be a good problem for AI Gemini. You'll need to
give Gemini Every Little Detail about your Truck and I mean
Everything. Gemini will pull everything that it can find about this
problem,, and Might be able to offer you What the Problem
Might Be. AI is not Perfect Though,, so You have to consider
everything AI says as a possibility, but Might just give you some
idea's to Check Out.
eddiem98
U.S. - Hawaii
Posted: Oct 25 2026 at 11:43pm | IP Logged Quote eddiem98
Rubble, thanks againg for checking in with me. The truck
is completely stock, nothing has been altered and its not
raised, has new tires from Costco and are balanced the
noise was there before and after the tires were put on.
It is not a Differential or wheel bearing noise, it
sounds more like when your tires are not balanced
correctly.
The truck only has 60K miles, we are looking at the rear
axels now as well as the rear end diff bearing.
Again thanks for the help.
Aloha
EM
Rubble
Posted: Oct 26 2026 at 1:18am | IP Logged Quote Rubble
me. The truck
correctly.
Aloha
EM
While you're at the Rear Diff Houseing, it's a good idea to
Check the Breather out, Clean around the Breather 1st, Then
take it out and clean it out with diesel fuel and blow it out with
compressed air, antiseize Grease on the Threads and put it
back in..
The Service manual doesn't give a maintenance
schedule for this,, but I try to do mine about once or twice a
year. If driveing through Mud and Water,, then cleaning the
Breather and Changeing the Oil more often than the
maintenance schedule might be a more prudent thing to do.
Hopefully you didn't have a leak,, and still have adequate oil in
the Rear Axle Houseing. Mine only holds about 1 1/2 qts, so it
doesn't take much of a leak to not have enough oil in
the axle houseing for lubrication.
Hope you're able to find what the problem is.
eddiem98
U.S. - Hawaii
Posted: Oct 27 2026 at 11:44pm | IP Logged Quote eddiem98
Rubbble, no leaks on the rear end changed the oil and put
spec Nissan Oil in there, topped it off a couple of
months ago. The truck has the following BRAND NEW.
1-Rotors and Breakes
2-EBrake Shoes
3-New shocks and Struts
4-New Clutch (Stage 2)
5-New Differential ( Completely new)
6-New tires just rebalanced at Costco
7-Rear end oil changed Valvoline 75W-140
Rubble
Posted: Oct 28 2026 at 12:14am | IP Logged Quote Rubble
2-EBrake Shoes
With the Truck only having 60K Miles, I've got to wonder what
has this Truck been Through ~ New Clutch, Differential, etc.
I'm not saying that it was abused, but @ 60K Miles, these parts
wearing out this soon, something has got to be going on.
These 2nd Gen Frontier's have been known to go a long long
time. One owner was verified to get 1 Million Miles on his and
he was useing his in His Delivery Service Business.
Sounds like you are trying hard to take care of your Truck
Though.
Did you have your Wheels Checked out for being bent? Maybe
somebody ran over a curb or a deep pot hole, etc. I've had that
happen on the 1993 Nissan Truck that I had. Sometime's with a
bent wheel, I can feel it when going slow and turning in a circle,
I could feel it in the steering wheel.
Did You pose your problem to AI Gemini?
Gemini helps me with all sorts of problems and even has a
sense of humor. :-)
eddiem98
U.S. - Hawaii
Posted: Oct 31 2026 at 1:00pm | IP Logged Quote eddiem98
The truck has not been abused at all. The clutch needed
to be replaced as my Son totally burnt the plate and
started slipping. The diff was replaced because of rust
some of the weights got dislodged and eventually the
carrier bearing went.....It was cheaper for me to replace
the DIFF than having the differential replaced with a new
one than having the old one balanced, the carrier bearing
replaced...
The wheels are straight no bumps of bends at all, they
were rebalanced at Costco with 4K miles on the tires....
I still think it is the differential making noise for not
being properly balanced.
Aloha
Rubble
Posted: Oct 31 2026 at 2:53pm | IP Logged Quote Rubble
clutch needed
replaced...
Aloha
I wish I knew something better to offer, but I'm not a professional
mechanic. I do try to do all the maintenance on my own
machines ie Truck, Tractor, etc and try to pull from my own
experience,, but that's about it for me.
I do use AI Gemini to help me out though,, and It has been a big
help to me on The Motored Machines, Home maintenance,
Appliance's, Electronic's, etc. ~ You Name it,, and Gemini has
been a big help to me.
I do remember back when I was a young person though,, and I
can tell you that I did abuse my Dad's, Truck, Car, Tractor's, etc.
It took me a long long time to Understand that I needed to Try
and Take Good Care of the Vehicle's,, and Not to do anything
that might damage them.
It took me until I was 30 years old,, before I realized that what I
needed was a Pickup Truck and Not A Fast Car... 8 years later I
got my 1st Brand New Pickup Truck and Never Looked Back.
I'm on my 3rd Pickup Truck now. I still want a Corvette, Porsch,
AirPlane, etc,, but I've come to realize that NEED is Waay More
Important Than WANT is.
