| Posted: Nov 25 2006 at 7:43pm | IP Logged
My back up lights are on whenever the trans is in a gear, any gear, anything but neutral. I have replaced both the neutral and back up light switches on the trans. Two mechanics have wasted over 5 hours looking for something obvious like a broken wire or ???? The lights come on whenever the trans is in a gear. When I shift from one gear to another, the lights go out when in neutral. The fix I have used for now is to unplug the back up switch at the back of the trans, wrap the two plugs in tape and stick a flashlight out the window when I need to back up. Truck is a 2001 Frontier 2wd extra cab 4 cyl 5 spd with 90,000 miles. This problem was a dealer installed option ( not on purpose) when I bought the truck 3 months ago. Any ideas??
