| Author |  |
        | superjammer Newbie
          Hi there,
           | Posted: Nov 30 2006 at 9:05am | IP Logged |   |
 I just bought a 2001 Frontier, and one of the problems it has is that the heater (blower) switch works only on 4. I have a feeling this is a typical problem, and I apologize if this gets asked all the time. Anyway, it's rather annoying, and I'm looking for a simple DIY fix. Can anyone help? Much obliged.
        | Back to Top |     |
        | sidclaim Newbie
 U.S. - Virginia
          I have 1999 Frontier and have the same problem, the number 4 speed blower is not working. I have to giggle between 2 and 3 to make speed number 3 work.  I think the blower speed selector is one piece. I have not actually taken it apart.
           | Posted: Dec 14 2006 at 9:46pm | IP Logged |   |
        | Back to Top |     |
        | 99FRONT Newbie
          I HAD IDENTICAL PROBLEM AFTER A FIELD MOUSE  GOT INTO THE VENTALATION DUCT AND ATTEMPTED TO NEST INSIDE THE BLOWER .  MUCH TO THE DEMISE OF THE MOUSE , IT WAS SUBSEQUENTLY DECAPITATED WHEN I TURNED THE BLOWER ON  WHICH OVERLOADED THE CIRCUIT.  THIS IS A QUICK FIX BY REMOVING THE ENTIRE  GLOVE BOX UNIT  (3 OR 4 SCREWS)  AND EXPOSING THE BLOWER RESISTOR.  IT  IS BASICALLY A PRINTED CIRCUIT BOARD ABOUT THE SIZE OF AN INDEX CARD AND CAN BE FOUND BY LOCATING THE WIRE HARNESS WHICH HOLDS IT IN PLACE.  NISSAN DEALERS USUALLY HAVE THESE ON HAND FOR ABOUT  $21.  GOOD LUCK!!
           | Posted: Jan 27 2007 at 10:24am | IP Logged |   |
 THIS  WHOLE PROCEDURE CAN BE DONE IN ABOUT  10 MINUTES WITH PHILLIPS SCREW DRIVER AND A FLASH LIGHT!
        | Back to Top |     |
        | sidclaim Newbie
 U.S. - Virginia
          Are you talking about the slide blower switch 1 thru 4 or blower itself?
           | Posted: Feb 01 2007 at 9:14pm | IP Logged |   |
        | Back to Top |     |
        | 98_F-SER Newbie
 U.S. - Kentucky
          there is resistor for settings 1-3 and a separate one for setting 4. not too expensive. i had the same problem with my 94 altima.
           | Posted: Feb 07 2007 at 4:20pm | IP Logged |   |
        | Back to Top |     |
        | fishoholic Newbie
 Canada
          Stupid thought, but I had a similiar problem with my blower, it turned out the nob was stripped and busted, couldn't even tell, dam plastic parts, like i said stupid thought but it would be nice if thats all it was.
           | Posted: Feb 08 2007 at 9:55am | IP Logged |   |
 If it ain't dirty and in the bush, buy a car!
 1999 Fronty SE
        | Back to Top |     |
