rmacdona Newbie
Posted: Jan 22 2007 at 3:19pm | IP Logged
I have a 2007 Nissan frontier and hate the ABLS, can I buy a regular limited slip differential? Where?
Thanks all.
JFordBronco Groupie
Online Status: Offline Posts: 54
Posted: Jan 22 2007 at 3:43pm | IP Logged
I am not sure about that. I also have the ABLS crap. It sucks....bad.
Joel
__________________ 2005 Nissan Frontier Nismo - tow rig. 1995 Ford Bronco XL with 6" lift and soon to be 35's and 2007 Yamaha Big Bear both are my play toys.
rmacdona Newbie
Posted: Jan 26 2007 at 9:50am | IP Logged
O.K. appartently there is not any aftermarket limited slip replacements. So my next thougt is a nismo rear end with the e-locker. Any one heard of this?
anyone seen on in your local salvage yard?
JFordBronco Groupie
Posted: Jan 26 2007 at 4:10pm | IP Logged
I have it in mine. Why dont you just buy a Detroit Electrac or a Eaton E-lock for it instead of having to go that route? You should have a Dana 44 in the rear. Even at that, try an ARB air locker. All three of the above are selectable lockers and are nice.
Joel
rmacdona Newbie
Posted: Jan 29 2007 at 11:02am | IP Logged
I didn't think any of the air lockers fit the 2007, thanks I will try that.
Also, which fuse needs to be removed to disable the abls (I know that it will disable the abs also), is there a swithch mod for that fuse? How does it work?
JFordBronco Groupie
Posted: Jan 29 2007 at 3:10pm | IP Logged
I am by no means a Nissan guru, but I dont see why it wouldn't. The other questions....I dont know.
Joel
rmacdona Newbie
Posted: Jan 30 2007 at 9:22am | IP Logged
I can't find one that fits?
04desertrunner Newbie
Online Status: Offline Posts: 37
Posted: Feb 21 2007 at 7:40am | IP Logged
Do the 04 king cab xe desert runners have some sort of lsd? It feels like it does.
__________________ - Oliver
04 Frontier KingCab XE Desert Runner "Dogs Like Trucks"
Former 240sx guy, ka24de-t for life!!!
Frontyfan Senior Member
Posted: Feb 21 2007 at 12:54pm | IP Logged
04desertrunner....according to nissanhelp.com both the XE 4x2 and XE4x4 (desert runner was built on that chassis i believe and had same suspension) do not have LSD, only the SE/SC models for that year. however it doesn't not specfically mention the desert runner
Posted: Feb 21 2007 at 7:16pm | IP Logged
Frontyfan wrote:
04desertrunner....according to nissanhelp.com both the XE 4x2 and XE4x4 (desert runner was built on that chassis i believe and had same suspension) do not have LSD, only the SE/SC models for that year. however it doesn't not specfically mention the desert runner |
Well then that confirms it. I jacked the rear end of the truck up in the air and spun the wheels....they spin in opposite directions damn it!!! I was really hoping for an lsd in this thing.
What are my options for a daily driver and occassional off-road excursion? I realize this is a 2wd truck but they just aren't as fun with out an lsd.
