| Posted: Jan 24 2007 at 10:08pm | IP Logged
Since this is your first vehicle, I wouldn't suggest raising and putting too big of a tire on. It'll effect your gas mileage, and next thing you know you'll be questioning taking it out because you'll have to put gas in.
Since you want 4-6 inches, definitely suspension lift. Body lift will give a horrible stilt effect, and you'll be swaying before you know it.
I think a mild lift with slightly larger tires will do just fine. You won't get your 4-6 inches, but it'll look aggressive.
