| Posted: Jun 27 2005 at 7:39pm | IP Logged
welcome to the org. intakes can be found here www.4x4parts.com not quite sure if the lift kits found there will fit the new trucks.
As for exhaust... it's actually cheaper to go out and have a shop put 2.5" piping, your choice of muffler and tip(s). You'll get about the same performance as a cat-back and half the cost.
btw... this should be in the modifications section... I went ahead and moved it.
