| Posted: Sep 20 2007 at 6:28pm | IP Logged
Ill put in my two cents on the Vg30dett.. Great motor, but pricy, fabricating will be fun, and two turbos arnt always better than one... that motor is very finicky... also when modifying it, you will more than likely loose your wallet and your patiance... also as a side note it would cost you about 6,000 to have a performance shop swap the turbo motor into a non turbo z32 non turbo body... that it belongs in, so think about the cost of it into your truck.
or for about a 1/4 the price long block trany and turbo stuff at about 3k
If your going for a v6, just buy any rear wheel drive vg30e... the non turbo from anything 88+ these are W series motors with larger wrist pins and better collant veins, oil squerters ect... just a better motor... then buy turbo exhaust manifolds from any year 84-89 turbo, all vg motors have forged internals and can handle about 8-10 psi fairly well. the NA vg30e will have a higher compression than the turbo, but is still only 9:1 so your boost responce will be quicker. Also note, that if you buy a pathfinder Vg30e.. that the cams are differant and will lack high hp. swap them with any 84-89 300zx cam, turbos and non turbo have the same cam. heads are the same, just a diferant intake plenum and destibiter cap.. maxima destribiter is better , use maxima altanator as well, um... buy a z32 300zxtt feul pump. This motor is good for anything along the lines of 300- 480 wheel hp depending on how extencive your modifications will be. join the zcar.com forum if this route seams afordiable... please note... the people in that forum at stuck up and rather than telling you what you need to know, they will point you in the direction you need to go though... and no other forum knows that motor better .
or be cheap and do what every one does...
just buy GM... make it carb, and run push rods...
i'd say more, but i dont want to over post... pm if more info is wanted.
Nate
__________________ It may not be big, but i can sure get in and out of some tight places.
84 300ZX-T
89 240SX coupe
06 nismo frontier
