watkinsfl Newbie
| Posted: Oct 11 2009 at 4:29pm | IP Logged
Can someone help me to determine the best place to run my fog light harness through my firewall? I have a 2007 Frontier 4.0L. Thank you, Tim
__________________ Tim
| Posted: Oct 11 2009 at 7:23pm | IP Logged
Everything is already there as far as wiring goes. Here is the rest of the parts needed: Update on installing fog lites in a Frontier SE 08 Following parts needed: 1 - 25540-ET11A switch 1 - 26150-EA825 lamp 1 - 26155-EA825 lamp 1 - 62256-EA800 bezel 1 - 62257-EA800 bezel 4 - 08146-6162G bolts The switch is from an 08 Pathfinder SE or 08 Frontier LE, the rest is from a LE or Offroad Frontier w/ chrome bumper. I
verified this switch works by removing it from the 08 Pathfinder and
plugging it into an 09 Frontier SE(same as an 08), had power and ground
at the fog lite connectors. A lot easier than the way I did my own
set-up with the '95 harness, switch and relay!!! This will work on the 07 also.
watkinsfl Newbie
| Posted: Oct 12 2009 at 7:33am | IP Logged
Hey thanks Frontierguy. I didn't realize it was prewired. Thanks again! Tim
