Subject Topic: tires Post ReplyPost New Topic
jennaK
Posted: May 26 2010 at 6:46pm | IP Logged Quote jennaK
So I need new tires. But more than that I want to upgrade them. I do not
want to have to lift my truck...can I just put slightly larger tires on the stock
rimes?
jennaK
05 Frontier SE
Back to Top View jennaK's Profile Search for other posts by jennaK
Posted: May 26 2010 at 8:57pm | IP Logged Quote frontierguy
WHY?????
dmartin16
Posted: May 27 2010 at 1:01am | IP Logged Quote dmartin16
I have 30.5x9.5x15 on stock XE/SE rims.. and they look and sound great.. and feel great too.. overall if I had to do it over again, I'd see if I could go up to something like 265/70/15 but that's about all I'd do.. they're both about the same, but mine are a bit wider.. I'm almost positive you could fit 31's with 0 rubbing and a possible 32 with a bit of rubbing.. maybe crank the torsion bars a bit and do no rubbing.. dunno if it's possible.. Frontierguy, anything else?
2003 Frontier XE (Base)
Back to Top View dmartin16's Profile Search for other posts by dmartin16
jennaK
Posted: May 27 2010 at 1:55pm | IP Logged Quote jennaK
Thanks! I will look into it
jennaK
05 Frontier SE
Posted: May 27 2010 at 3:14pm | IP Logged Quote lakota
jennaK:
Welcome to the group!
There are eight or more unrelated suspension and running gear systems in the 1998 to 2010 Frontiers.
Have a good one while you can afford it! Don S..
Here is a paste-up list of some the things needed for comparing wheels.
Diameter – width – lug pattern – back space – centering hole size - lug/hub centric? (centering) – stud size - lug style – lug size -
Titan Bolt pattern is 6-5.5" also listed as 6-139.7mm sometimes.
Weld's wheels application catalog references Titan hubs as 3.072” HUB I.D
The 1999 Frontier Se cast aluminum 4x4 wheels are hub-centric, 6 lugs on 5.5” dia., 15”dia. X 7” wide, 5.250 Back Spacing, centering hole is 3.925 inches in diameter.
TIRES
http://www.discounttire.com/dtcs/infoTireMath.dos
. Modifying a vehicle with lifts and larger or wider tires is detrimental to fuel mileage and brake life.
dannyg
Posted: May 31 2010 at 9:14pm | IP Logged Quote dannyg
I`ve got 265-75-16 thats bout a inch taller than the 265-70-16 that came on mine it hurt town mpgs some was getting 17- 18 now 15-16mpgs
06 frontier 4.0 auto
