Cracker39 Newbie
| Posted: Feb 21 2014 at 6:01am | IP Logged
I'm making mods to improve performance to tow a 4400 lb travel trailer. I've already opened up the exhaust system behind the cat converter with a dual inlet muffler and larger tail pipe and have a cold air intake ordered. I plan to put synthetic fluid in my manual trans pan and the differential already has it. But, I also want finned differential cover and finned or deeper trans pan to improve fluid cooling while under the load of towing the trailer. Can anyone help with sources for these?
I found this diff cover, but can't verify that it fits my '06 with 6-speed manual trans. The bold pattern looks exactly like the one on my truck.
http://www.ebay.com/itm/SPICER-DANA-44-NISSAN-ALUMINUM-FINNE D-FAST-COOLING-DIFFERENTIAL-DIFF-COVER-/360844367061?pt=Moto rs_Car_Truck_Parts_Accessories&hash=item54040014d5&vxp=mtr
Any other suggestions for improving towing ability would be appreciated too.
Thanks...
__________________ Dale (The old Florida Cracker)
06 Silver Frontier SE, V-6, 6-spd, CC
| Posted: Feb 23 2014 at 6:29pm | IP Logged
If you have an M226 rear diff., you can use the finned
cover from a Titan. You will need the bolts also(longer).
There is no "finned" pan on your manual trans. I just
noticed your sig., the CC uses the C200 rear diff if my
memory serves me correctly.
| Posted: Feb 23 2014 at 6:49pm | IP Logged
Model Axle Gears
XE KC 4x2 5M C200 4.083
XE KC 4x2 5A C200 3.692
SE KC 4x2 6M M226 3.538
SE KC 4x2 5A C200 3.133
SE KC 4x4 6M M226 3.538
SE KC 4x4 5A C200 3.133
SE CC 4x2 6M M226 3.538
SE CC 4x2 5A C200 3.133
SE CC 4x4 6M M226 3.692
SE CC 4x4 5A C200 3.357
NISMO KC 4x2 5A M226 3.133
NISMO KC 4x4 6M M226 3.692
NISMO KC 4x4 5A M226 3.357
NISMO CC 4x2 5A M226 3.131
NISMO CC 4x4 5A M226 3.357
LE KC 4x2 5A C200 2.937
LE KC 4x4 5A C200 3.133
LE CC 4x2 5A C200 3.133
LE CC 4x4 5A C200 3.357
| Posted: Feb 23 2014 at 6:53pm | IP Logged
Also, if you have an e-locker it is an M226
If you have a 6 speed with or without e-locker it is an
M226
Non locked and autos are C200
(All NISMO and Pro-4x are M226)
c200k - 8 bolt
m226 - 12 bolt
