Subject Topic: differential Post ReplyPost New Topic
valentin_84
U.S. - Arizona
Posted: Aug 06 2006 at 4:51pm | IP Logged Quote valentin_84
well guys i got stuck in the desert yesterday for an hour. it sucked! it wouldnt of been bad if i had a limited slip differential because my right rear tire(the side that doesnt do anything) was on hard ground but the left was throwin sand everywhere and diggin deeper and deeper. i was just wonderin if there are good and cheap aftermarket lsd's for 2001 frontiers or if i could take one from another frontier in a junk yard? what should i do so it doesnt happen again?
valentin
Back to Top View valentin_84's Profile Search for other posts by valentin_84
Posted: Aug 07 2006 at 6:51am | IP Logged Quote kcidmil
Nismo offered some at one point, but they had a model and drivetrain limitation on it.
hintonl
Posted: Aug 07 2006 at 1:21pm | IP Logged Quote hintonl
you can find stock LSD's on the web fairly cheap whats a killer is the shipping try www.car-parts.com the stock LSD's are not that great from 01 to 04 if you can get ahold of on one you can mod it to go from 130ft.LBS break away to 280 you just need to get some extra parts. if you locate one pm me and Ill get you the write up on how to do it you.
2K Crew Cab Converted to 4X4
ekaphoto
Posted: Sep 05 2006 at 1:41am | IP Logged Quote ekaphoto
A cheap LSD mod that works is to push slightly on your gas pedal when the wheel is slipping. It will stop the wheel from spinning and help in a situation just like that.
Back to Top View ekaphoto's Profile Search for other posts by ekaphoto
