Subject Topic: High beam trigger Post ReplyPost New Topic
Tomaszs
Posted: Oct 04 2026 at 9:54am | IP Logged Quote Tomaszs
Hi.
I have a auxbeam ks-80 controler that has an option for
triggers.
Does anyone know if there is a wire coming from momentary
high beam switch (pulling turn signal lever in) or is
everything controlled by can-bus?
I would like to wire light bar to be triggered by high
beam but only when I pull the lever not when they auto
activate so using a fuse or pulling signal from the
headlight isn't what I want to do unless there is
separate fuse for automatic and momentary high beam.
2026 frontier pro 4x
Back to Top View Tomaszs's Profile Search for other posts by Tomaszs
Rubble
Posted: Oct 04 2026 at 1:35pm | IP Logged Quote Rubble
Tomaszs wrote:
Hi.
triggers.
This sounds like a question for the Nissan Service Dept
Manager or Electronic Master Tech.
Also Gemini AI might also be able to explain all this for you, if
You Give All The information that they ask for.
You'll need to have some way to verify what Gemini tells you
though, as you can't take the information as Gospel.
