Subject Topic: desert runnin Post ReplyPost New Topic
valentin_84
U.S. - Arizona
Posted: Aug 09 2006 at 8:50pm | IP Logged Quote valentin_84
ok guys i have a 01 xe with a 4 cylinder and a 5 speed. i wanna build it up to be able to run in the desert. now i dont have much money so i cant go crazy. i guess i need a skid plate and i dont wanna go 4x4 i think ill do fine with a good lsd and i already have oversized tires i just need a lift i guess? i dont want a big one. just enough to run around. what size lift would i need? im good with the engine power i think. what would i need in all to build this thing? how much would it cost?
valentin
Back to Top View valentin_84's Profile Search for other posts by valentin_84
Posted: Aug 10 2006 at 7:41am | IP Logged Quote kcidmil
You could really bring it alive by going with some JWT parts, and upgrade the clutch.
The more you can swap out suspension wise, the better.  I would spend the extra money and get some Bilstien Remote resivoirs.  Either a 5150, or 7100 series.  The amount of desert running you do, will determine which one to get.
A 6" lift would give you some room for travel, depending upon the tires you get.
