NeonspeedRT Newbie
| Posted: Sep 15 2006 at 2:12pm | IP Logged
I'm looking for a set of OEM fog lights for my 04 Frontier. I want the factory kit that comes with the lights, switch, wiring, etc. I can find them all day for the 05 and up, but none for the 04.
Does anyone know where I can buy the OEM light kit? I've checked on all the Nissan boards I know of and I can't find anything. I see plenty of knockoff's on ebay that are "factory style" but not OEM.
If anyone can help me out, it would be greatly appreicated. Thanks. Chris
__________________ 2004 Frontier Desert Runner
1997 CBR900RR
hintonl Senior Member
| Posted: Sep 15 2006 at 3:29pm | IP Logged
Ebay might work for you
NeonspeedRT Newbie
| Posted: Sep 15 2006 at 3:52pm | IP Logged
I've been looking on there for the past month. I have found nothing but knock off lights. No OEM.
1997 CBR900RR
| Posted: Sep 15 2006 at 4:26pm | IP Logged
Then contact a dealer I dont see the point in spending big money on OEM fog lights when you can go to wally world and spend 25-30 bucks for a set just my .02
try this link
http://www.4x4parts.com/public_html/shop/index.php3?page=sho p/browse&category_id=a3b099760733d0a8af60263ce27184f5&am p;ps_session=cbc6e494f7847fc412cca038118ca2f1
richs1 Newbie
| Posted: Oct 01 2006 at 6:31pm | IP Logged
Don't know if you have found what you were looking for, but I am in the process of adding the OEM fog lights to my 02 CC. If your frontier has electric windows and locks, chances are it is already wired for the fog lights. Check on the headlight harness behind the radiator support, there should be a plug on each side taped to that harness. If it is, you can add the OEM lights and change out the turn signal lever on the steering column with one that has the turn ring for the fog lights. You may also have to add a relay to the fuse box under the hood(mine already had the relay). I have found the lights at Pinnacle Nissan ( nissanparts.org) for $65.00 each, the turn signal lever for $52.00. Relay if you need it is around $8.00 I agree with the last poster that it is a lot of money, but I prefer the Original equipment look so i did not mind spending the extra money. You can also find the lights at a salvage yard. Go to google and search for used auto parts, I think there is one there called car parts.com. I found several there, but chose to buy the new ones. Hope this helps.
StormCrew Newbie
Online Status: Offline Posts: 19
| Posted: Oct 02 2006 at 6:13pm | IP Logged
richs1 wrote:
| Don't know if you have found what you were looking for, but I am in the process of adding the OEM fog lights to my 02 CC. If your frontier has electric windows and locks, chances are it is already wired for the fog lights. Check on the headlight harness behind the radiator support, there should be a plug on each side taped to that harness. If it is, you can add the OEM lights and change out the turn signal lever on the steering column with one that has the turn ring for the fog lights. You may also have to add a relay to the fuse box under the hood(mine already had the relay). I have found the lights at Pinnacle Nissan ( nissanparts.org) for $65.00 each, the turn signal lever for $52.00. Relay if you need it is around $8.00 I agree with the last poster that it is a lot of money, but I prefer the Original equipment look so i did not mind spending the extra money. You can also find the lights at a salvage yard. Go to google and search for used auto parts, I think there is one there called car parts.com. I found several there, but chose to buy the new ones. Hope this helps. |
Has anyone added Fog Lamps to an 06 SE Crew Cab???
I have the power package, a blank out plate near the power mirror switch (wiring behind?), and the daisy wheel looking plastics in the bumper where the lamps should be.
Doesn't look too tough?
Thank You.
richs1 Newbie
| Posted: Oct 02 2006 at 11:49pm | IP Logged
Don't know much about the 06 frontier, but a good place to start is to find out where the fog lights are activared on an 06. If there is a switch on the dash, then you probably have an empty spot for the switch. It may be like mine and the on/off switch is intergrated into the turn signal, if it is you can purchase a new turn signal lever and install(I changed my switch out this morning, took about 10 minutes). Next, check the headlight wiring harness to see if there is a loose wire for the fog lights( it will likely be taped to the headlight harness). If it is already wired, then there will be identical wires on both sides. there is a good chance that it is already wired due to the fact that all of these vehicles are built on an assembly line and it would be too time consuming to wire each vehicle based on it's particular options. You will probably not get much help from the parts department at your local dealership, most of them do not think you can add options that were not installed when the vehicle ws built. If you can find a parts guy with an open mind, they can be a big help. Let me know what you find out. Good Luck.
NeonspeedRT Newbie
| Posted: Oct 06 2006 at 11:25am | IP Logged
Excellent information. Thanks I appreciate it. I'll check this weekend and see if i'm prewired. I do have the power windows/locks, so hopefully I am.
1997 CBR900RR
GKreamer Newbie
| Posted: Oct 28 2006 at 10:01pm | IP Logged
Were you able to find out if you are prewired?
06blackse Newbie
| Posted: Nov 01 2006 at 4:54pm | IP Logged
www.courtesyparts.com/frontier/D40_index.html
Here's where I found some
