SC02Truck Newbie
| Posted: Sep 21 2005 at 11:05am | IP Logged
Like the title says im looking peoples Comments and Experiences with these Supercharged trucks. Good or bad im close to buying one so would like to know if i should look for anything when i check out the truck. Thanks
__________________ 2002 Nissan Frontier
3.3L Supper Charged
4 Door short box
Yellow Exterior, Dark gray interior
| Posted: Sep 21 2005 at 12:07pm | IP Logged
My only suggestion is to switch out the supercharger if you don't mind the warranty being voided.
The eatons they put in there suck.
SC02Truck Newbie
| Posted: Sep 21 2005 at 12:47pm | IP Logged
so what Supercharger should i put on, and what do you mean by suck? Do the factory SC's go out? or what?
3.3L Supper Charged
4 Door short box
MileHigh S/C Groupie
| Posted: Sep 21 2005 at 2:06pm | IP Logged
They don't wear out easily, they just don't have whip your head back power. The one thing that I hate is the intake noise. Its not aggressive, its just a big loud whine, it got worse when I installed the Nismo Cold air intake. But it also got a little faster. You could also change out the pulley on the S/C unit and that will make it spin faster, thus compressing more air. I am not 100 % sure that the Eaton Supercharger is the cause of the lack of power, I beleive that the VG engine is a tired powerplant that been around since the early '80's and adding a supercharger was Nissan's way to spice it up with out changing the motor, for a truck that was approaching the end of its design life. Even the '90's Twin Turbo ZX only had 300hp, the Fronty had 220hp, I think it was maxed out. Thank God they changed to the VQ platform for '05
__________________ You Ain't Got No Thing if it Ain't a Supercharged Thing!
'04 Frontier 4X4 S/C Crew Cab Long Bed
Nismo Cold Air Intake
SC02Truck Newbie
| Posted: Sep 21 2005 at 2:38pm | IP Logged
yeah im very familier with SC and TC. My question is mostly is there something common that fails on these trucks? Anything at all i should really look at while checking this truck out?
3.3L Supper Charged
4 Door short box
| Posted: Sep 21 2005 at 3:28pm | IP Logged
heres something I forgot to mention and I found out about it after I bought mine, the S/C Frontier Requires Super unleaded, you can use mid-grade but your never suppose to use Reg. Regular is really hard on the knock sensor. If the knock sensor goes out it will make the supercharger go in to "fail safe mode" this means the engine is only able to rev to 2400 rpm's until it is fixed.
You may want to check into if the rockers were replaced, from '99-'03 the rocker would tick when they were cold, only about 2-3 secs. Nissan replaced a bunch with new one. Nissan says 1 sec of ticking is ok and normal.
| Posted: Sep 21 2005 at 3:34pm | IP Logged
This web site has reviews, specs, recalls, service bulletins for the 02 fronty!
http://www.nissanhelp.com/Models/2002/Frontier/Description.h tm
SC02Truck Newbie
| Posted: Sep 21 2005 at 3:40pm | IP Logged
Thanks! The owner now of the truck im looking at says he has done all the recalls that Nissan has sent to him. He is the original owner of the truck.
3.3L Supper Charged
4 Door short box
SC02Truck Newbie
| Posted: Sep 22 2005 at 8:49am | IP Logged
Whats the engine name/number for the 2002 3.3L SC Frontier?????
3.3L Supper Charged
4 Door short box
| Posted: Sep 22 2005 at 12:54pm | IP Logged
VG33DE is the regular model number.
