Subject Topic: 1st Gear Clunk Post ReplyPost New Topic
Nismology
U.S. - New York
Posted: Apr 06 2008 at 10:11am | IP Logged Quote Nismology
I have a 08 Nismo 6spd, it has less than 1100 miles on it, and ive noticed once in a while in first gear it sounds like a clunking sound is coming from the rear. I think I heard it a few times in other gears, but im not sure...im just starting to pay attention now, as im hearing it quite a bit. Thanks
Back to Top View Nismology's Profile Search for other posts by Nismology
Posted: Apr 07 2008 at 11:01pm | IP Logged Quote lakota
Nismology;
I did a search using 'abs noise' so here is a bunch of things to read that might give you some insight. (hopefully)
http://www.nissanfrontier.org/search.asp?KW=abs+noise&SM =1&SI=PT&FM=0&OB=1
Why is it that the politicians in D.C. are the only ones that don’t know there are better things to make Ethanol out of than corn?…  Answer… They know! They know! Guess why they don’t correct the problem.
