| Posted: May 18 2008 at 9:24am | IP Logged
Heres a how-to for ya. http://www.nissanoffroad.net/how_to/torsion_bars/tors ion_bars.asp
If the link dont work just go to nissanoffroad.net. go to the how to guides at the top of the page, then Frontier/Xterra, then torsion bar adjust. This will give you a few pics as well as a step by step process for you to follow.
Its pretty simple all you "HAVE" to have is either a 3/4" or 19mm cresent wrench and a 3/4" or 19mm rachet and socket. Havng a jack around is a plus, bc you can jack the front end up and take some of the pressure off of it, makind the torsion bar bolts a whole lot easier to turn.
