| Posted: Jun 01 2010 at 7:11am | IP Logged
Your speedo will read slower than what you're actually going, and the ABS won't work quite right, on the other hand that is quite a bit more rubber on the tire and will require more brake force to slow them down which will negate some of the need for ABS. On snow and ice it will still work like it's supposed to.
The only thing, I can't remember if you need a mild lift to clear those 33"s. Though I'm sure someone will be along to chime in on that.
