| Posted: Aug 31 2010 at 7:28am | IP Logged
There always seems to be interest on this board about oils so I thought I would update you all on my 2007 Crew Cab V-6 auto Frontier. I just hit 31,000 miles ans since I moved to central PA where it is colder, I wanted to change out the old fluids and run something a bit more in keeping with the winter temps and even the hot summer temps to come.
Rear and front diffs: Mobil 1 75W-90 (I have the C-200 rear). Have used this in the rear since I drained the factory fill at 1000 miles but it is new for me in the front diff where I had used Valvoline SemiSyn 80W-90.
Transfer case: Mobil 1 Dexron/Mercon ATF Synthetic. This is a basic match for the Matic D but is fully synthetic.
Engine: Mobil 1 0W-30 with a Purolator Pure One filte.
Auto trans: Drained out 4 qts from pan and added 4 qts. Nissan Matic S.
Everything went well, used new copper or aluminum washers from Nissan as required and torqued all bolts to spec. Truck runs very nicely. Everything quiet and smooth. My last tank of gas gace me 20.0 mpg and this included some city driving. I use Shell high test which around here is $2.89/gallon. I did notice the black "fur" on all of the magnetic drain plugs from the diffs and transfer case but the amount was minimal and just made a black stain on a rag when wiped.
