| Posted: Feb 03 2011 at 6:52am | IP Logged
+1 to what Frontier guy says, especially the coolant. Much as I like to do a lot of my own service (oil changes, diffs, transfer case, air filter, cabin filter, drain and refill tranny), I will only let the dealer do a coolant change because of the equipment required to get the air out of the system.
I use all syn fluids in the diffs, by the way, and Mobil 1 ATF in the transfer case. Really helps in cold weather.
