Posted: Feb 26 2012 at 10:02pm | IP Logged
In the majority of truck brands wheel types vary bewteen two wheel drive and four wheel (4x4) drive. I know Very Little about 2005 and newer Frontiers.
You haven't told us what you are driving.
You will need to know Lug nut pattern, inter wheel diameter (brake clearance) center hole diameter and wheel off-set.
Go Here...
http://www.ask.com/web?qsrc=1&o=102502&l=dir&q=W heel+Fitment+Guide
The 1999 Frontier Se cast aluminum 4x4 wheels are hub-centric, 6 lugs on 5.5” dia., 15”dia. X 7” wide, 5.250 Back Spacing, centering hole is 3.925 inches in diameter... 1998 thur 2004 should be the same with 15", 16" and 17" diameters.
Hope this helps a little.. Don S..
