2000silvercrew Newbie
| Posted: Dec 06 2005 at 1:24pm | IP Logged
ok. i managed to fit 5 1/4 speakers in the rear of my crew cab. anyone else have any ideas? im trying to get components installed in the rear doors, but i am limited to room, due to the window brace. DEPTH is the issue. i have 6 3/4 components for the front, and really want components for the rear. any ideas?
thanks. marsh
__________________ 2000 Missan Frontier Crew Cab XE 3.3 V6. 5 speed. 4x4. Limited-Slip. K&N filter. 31" BF Goodrich All-terrains. NO fender flares.
| Posted: Dec 06 2005 at 5:59pm | IP Logged
How much space is between the speaker and door trim? My colorado has the same clearance issue for the window brace getting in the way... but there is enough room that I can add a spacer to use larger speakers.
| Posted: Dec 06 2005 at 9:59pm | IP Logged
maybe less than 2 inchs.
| Posted: Dec 07 2005 at 7:32am | IP Logged
I'd find out for sure. You could get a decent size speaker if you use a 3/4" MDF spacer ring... but that all depends upon if you would still have some room for excursion.
4xfrontyxe Newbie
| Posted: Jan 03 2006 at 7:55pm | IP Logged
i used the mdf spacers and i have a 01' crew cab fronty, i have 6 1/2 pioneers in the back doors and pioneer 6x9 in the front doors. i am running a 4ch amp to both of them. sound a million times better than the factory speakers.lol.
>John
__________________ Wouldn't ride anything but a Honda.....
| Posted: Jan 05 2006 at 12:57pm | IP Logged
whats an MDF spacer?
| Posted: Jan 05 2006 at 10:22pm | IP Logged
MDF spacer is just a piece of MDF wood cut into a ring to sit in-between the speaker and door mount. MDF can be found at your local home improvement stores (Lowes, Home Depot, Etc.)
Frontyfan Senior Member
| Posted: Apr 27 2006 at 12:57am | IP Logged
4xfrontyxe, what size MDF spacers did you use to fit those 6 1/2's in the rear and 6x9's up front? and were they a tight fit...what size amp are you running and would it be absolutely necessary to run an amp...i'm thinking that it wouldn't, because the factory stereo should be able to push enough to make any replacement speakers sound a ton better than stock speakers, i have an '01 fronty CC SE with the in dash 6-CD changer
gordopops Newbie
| Posted: May 07 2008 at 4:55pm | IP Logged
will this technique work with an 03 crew cab?
__________________ Confused Newbie W/
'03 SE CC DeuceWD Chort Bed
bmwproboi05 Newbie
| Posted: Aug 03 2009 at 5:27pm | IP Logged
gordopops wrote:
| will this technique work with an 03 crew cab? |
"spacers" work with any car. As long as you take into the account that your door might casue some probs of it being flush. So you might want to use some non hardening clay.
