| Posted: Aug 29 2008 at 9:58am | IP Logged
where exactly was all the antifreeze coming from? Engine or Radiator? It obviously sounds like you have something expanding and shrinking due to cold and heat.
When the truck was warmed up in the cold, did it still leak? A stuck Thermostat won't cause your coolant to leak, but your truck to overheat.
I'm almost willing to bet that because of the cold your waterpump shrunk a little, and gave a little bit of room around the gasket. Or part of the gasket material is gone. And once it's warmed up, it expanded back out enough to create a seal.
Without actually looking at your truck though, I couldn't tell you for sure. But at $900, sounds to me like the mechanic is trying to take you for a ride. All he'll probably do is just install a new gasket.
