blubear Newbie
| Posted: Nov 26 2012 at 4:38am | IP Logged
New owner of 2012 Nissan Frontier 4wd SV crew cab and one of the main reasons I went to the Frontier is so I could eventually purchase a Travel Trailer. I've done some research and I'm a little confused about max rates and all. Even though it's towing rate is 6100 lbs seems that I should stick to a TT no larger than 3500 lbs. Any suggestions or helpful tips & recommendations would be greatly appreciated.
thanks
__________________ Cindy
Boomer Senior Member
| Posted: Nov 26 2012 at 6:51am | IP Logged
1. Don't tow in OD.
2. Make sure if you have a heavier trailer that you have trailer brakes and a weight distributing hitch. Don't depend on just the truck brakes.
3. To avoid a lot of work on the part of the tranny, try to avoid stop/starts. Tow as much on the Interstate as possible.
4. ALWAYS use premium gas when towing. And I would recommend using a syn oil like Mobil 1 or Pennzoil Platinum/ Ultra.
5. Personally, I think that towing at the max rating is not a good idea. If you need to be routinely towing at 6000 pounds, get a Titan.
blubear Newbie
| Posted: Nov 26 2012 at 4:27pm | IP Logged
Thanks for the tips Boomer. I really don't intend towing the max and my thoughts were to keep TT Dry weight between 2800 - 3500. I need to find a TT that has (2) separate sleep areas, preferably @ either ends. Any thoughts
thanks again for your input
| Posted: Nov 28 2012 at 9:35am | IP Logged
Blubear, can't really help you with a trailer recommendation. Why not visit some places that sell them and ask a lot of questions. I used to work for almost 30 years for a major resilient flooring company and spent a lot of time at factories where our flooring was installed in travel trailers and modular homes. Believe me when I tell you that quality is all over the place. To keep weight down, lots of 1" X 1" wood is used in the frame along with thin aluminum sidind and plastic wheel wells. The old Airstreams that were "solid" aluminum were great. Why not consider a pop-up type trialer. Less weight, less wind resistance and easy to open and set up. Some even come with solid roofs that form the top shell of the trailer when collapsed.
blubear Newbie
| Posted: Nov 28 2012 at 5:21pm | IP Logged
Thanks for the information Boomer. I've actually thought about the hard side pop ups....I need a little more space. I've gone to a couple RV & Trailer Dealers and plan to visit some more in the future. Love the Airstreams, just out of my budget realm.
| Posted: Nov 29 2012 at 6:02pm | IP Logged
Thgere is also a contraption I saw for pickups that allows you to use the bed and tailgate to form the floor of a tent that goes over the back of the truck. Extremely spacious, low weight and apparently easy to set up and take down. Just a thought.
blubear Newbie
| Posted: Dec 01 2012 at 6:30am | IP Logged
Thanks Boomer. I guess I did enough of the "tent/canvas" camping throughout the years and just looking for an upgrade for my "golden years"
| Posted: Dec 01 2012 at 9:51am | IP Logged
Yeah, at age 65 I understand the golden years quite well. I love motels more than camping at my age. Love that hot morning shower, breakfast where I can read the paper and watch the news.
So now I am going to tell you to get one of those 45 foot V-10 motor homes with the side pullout, king size beds, large screen LED television, surround sound stereo, full kitchen (granite counter tops) and two baths. Tow the Frontier behind it!!!!
Seriously, let us know what you end up doing. That is always helpful to others on the board. Reviews of the product and the performance of your Frontier towing it would be most appreciated. Thanks in advance!
blubear Newbie
| Posted: Dec 01 2012 at 4:42pm | IP Logged
You are "funny" Boomer I just need to keep exploring all the different possibilities. One thing is for sure, I love my Frontier and I will find the best TT fit for the truck and myself. You've been a great wealth of information Boomer and fun to exchange posts.
| Posted: Dec 01 2012 at 5:06pm | IP Logged
Glad you enjoyed the posts and found them helpful. I am always quite interested in product reviews and performance reviews. I see too few sometimes on boards like this.
One other thing I would recommend. Drain and fill your diffs with synthetic oils. Your rear diff will take either 75W-90 or 75W-140, depending on whether you have the 200 diff or the other. Fill the front diff as well with the syn fluid. This will give you better thermal and spalling protection when towing. I do this and also use Mobil 1 ATF in my transfer case.
