| Posted: May 05 2007 at 7:38pm | IP Logged
I have an 05 4x4 manual. the only suspension mod I have is a 2" spacer in the fron so I could fit bigger tires. Eventually I'm looking at getting everything in the 4x4parts rock crawler suspension package; starting with TC upper controle arms and the rear add a leave and possibly revolvers. If anyone has experience with these products I would really apriciate some feedback.
Also, I heard that revolvers are cheap articulation and can resault in damge to the drive shaft, is this the case?
do you know of any other alternative products you would suggest I consider.
Hope to see you all at the goneMoab event. Thanks, Mitch
