| Posted: Jul 10 2007 at 10:03am | IP Logged
Its an known issue or should I say its pretty common check/ tighten up the hoses on the botton of the Resivor(sp) you can Also get a rebuild kit IE new seals from here www.courtesyparts.com here is the direct link
http://www.courtesyparts.com/betasite/xterra-wd22-2000-2004/ genuine-nissan-parts/steering/492-power-steering-gear/-c-14_ 80_511.html
I know it says Xterra but this kit will also work On Frontiers I have had the kit for awhile just have not got around to installing it hope this helps
