hotzuk Newbie
Posted: Aug 16 2007 at 8:56pm | IP Logged
Hello everyone,
I am about to purchase a 2001 Nissan Frontier 4x4 with the V6 engine. The car is in great shape and has 120K miles on it and is mechanically sound. The owner has indicated that the AC works but is not blowing cold. The dealership told him that the condenser is leaking. I am pretty handy. My question is that if the refrigerant has leaked out of the system can I perform the replacement myself without having to worry about pumping down the system prior to the replacement of the part. If the system is lacking refrigerant, my theory is that after the replacement of the part all I have to do is have the system reloaed with coolant and then pressure checked.
Oh yeah, this is my very first post! Also, is there anything else that I should replace while replacing the condenser (e.g. lines)? Thanks for your reply.
jjordan Newbie
Posted: Aug 20 2007 at 8:46pm | IP Logged
Be careful with the fittings- they can be tricky to repair/replace. Also, you might run into some resistance with someone just charging the system without doing the rest of the work. Try to find someone small time and they will be more likely to get it done for you. Is that a R12 system?
__________________ Nevada, Texas (Collin County)
-03 Frontier Crew cab, V6 5 spd
-04 VW Passat DIESEL Tiptronic Auto rigged out
BIO DIESEL POWERED
tonkasc01 Newbie
Posted: Sep 01 2007 at 9:26pm | IP Logged
al cars after like 95 are 134a the 2k1 frontiers are 134a systems and yes it could be done at home the fittings are clamp or screw on flare fitting the Refregarant is so legal you evac to the envrioment it does not have the Chlorine atom in it like R22(HOME) and R12(old-MVAC) you buy the cans of it at walmart avance autozone and other places just dont get over your head check the seals on the system and teh filter should be cleaned every 30000miles
__________________ 2k1 Nissan Frontier SC CC SB
2k6 Toyota Camry LE V6
