Subject Topic: 2006 Frontier IAT Sensor Location Post ReplyPost New Topic
BobE
Posted: Nov 24 2007 at 1:17pm | IP Logged Quote BobE
Does anyone know where the Intake Air Temperature sensor is located? I bought one of those chips to help with the gas milage and power, but the instructions do not tell me where my sensor is located. It talks about it being 2 leads, but not sure if the 2006 4.0l is 2 leads or many leads.
Please help.
Back to Top View BobE's Profile Search for other posts by BobE
thedave360
U.S. - Louisiana
Posted: Nov 25 2007 at 1:14am | IP Logged Quote thedave360
I don't have a 2006...or a v6, but look on your intake duct work. go from the filter to the throttle body. there should be some wires going to a sensor somewhere shortly after the filter, that would definately be the intake air temp sensor.
the way I found out is I unplugged the sensor and ran my truck, the check engine light came on...then I went to auto zone and got them to check the code. It was the air temp sensor, then they cleared the code.
Just curious, what is this chip...and why do you need to mess with your air temp sensor?
Shift_Your own gears
Baton Rouge, LA
'17 Frontier Pro4x/CC/MT
nocturnaldrive
Posted: Nov 25 2007 at 4:15pm | IP Logged Quote nocturnaldrive
I personally wouldn't trust any of those "chips". Messing around with the intake sensor can seriously screw up the engine.
If your chip is anything like the one my buddy bought all it does is "tricks" the engine into thinking the air is warmer than it actually is so the fuel mixture is leaner. That can lead to problems like shuddering and even choking the engine because it won't have enough fuel to ignite properly.... just my two cents.
Back to Top View nocturnaldrive's Profile Search for other posts by nocturnaldrive
hsckris
U.S. - North Carolina
Posted: Nov 27 2007 at 6:39pm | IP Logged Quote hsckris
I agree with nocturnaldrive,
Most of those sort of things are nothing more than snake oil.
I strongly recommend that you DO NOT use it.
06 Nissan Frontier KC SE 4x4.
03 Ford Focus ZX3.
dane0387
Posted: Jan 18 2008 at 2:36pm | IP Logged Quote dane0387
Back to Top View dane0387's Profile Search for other posts by dane0387
dane0387
Posted: Jan 18 2008 at 2:37pm | IP Logged Quote dane0387
Where did you buddy get the chip from?
nocturnaldrive
Posted: Jan 20 2008 at 3:36pm | IP Logged Quote nocturnaldrive
He likely got the "chip" from eBay... I call it a "chip" cuz all it usually turns out to be is just a resistor. These guys that sell the chips have gotten smarter and started enclosing the resistors in plastic housing to make them look like they'll actually do something, so watch out!
