| Posted: Jan 23 2008 at 4:57pm | IP Logged
I've had my '02 Crew Cab SC auto for about six weeks now, and I average about 16-17 mpg on 91 octane, about 1-2 mpg less on 89 octane, and 7.5 towing a trailer, all with 10% ethanol.
I've read lots of posts about the knock sensors going bad, and it would make sense to me that fuel economy would suffer when this happens. From what I've read, when knock is detected, all boost is vented to atmosphere. Then your engine is left with the extra drag of the supercharger and none of the benefits, causing the throttle to be opened farther for longer to reach the same speeds as when you're using boost.
look at the TSBs on nissanhelp.com for more on this.
