| Posted: Feb 21 2008 at 9:09am | IP Logged
Recently had a suspension lift done, ride and off roading is much better on and off road.
One concern is that i carry medium to heavy loads on a daily basis from 200-400 IBS, the truck would naturally sag with these loads but with the new lifted and more articulated suspension the bump stops are less than half an inch from the leaf packs, is this normal.Should i get a load spring or helper spring, and would the helper spring cause a stink bug look with the truck when there is no load present?
Thanks~
__________________ 2005 NISMO 4X4
4" Mid Travel Suspension Kit
Total Chaos A Arms
Radflo Coil Overs
Volant CAI
Banks Monster Exaust
Big Bear Lake CA
