| Posted: Jan 15 2009 at 5:39pm | IP Logged
That would be a poorly grounded Head Unit. I would suggest pulling the head unit, finding out where the ground wire is grounded to, and move it to somewhere better.
Your whining is actually feedback from the alternator. When you push on the gas, the RPMs raise, spinning your alternator faster. Causing the pitch to go higher through your speakers.
Moving the ground wire to a better spot, cleaning the spot it is at will help eliminate this.
