Subject Topic: Resetting Service Engine Light Post ReplyPost New Topic
01Frontier
U.S. - Illinois
Posted: Jun 11 2009 at 11:56pm | IP Logged Quote 01Frontier
I have had some idling surges in my 01 Frontier 2.4L over the past month.  Took it to the shop and they diagnosed the IACV was bad.  Up to this point just had the idle surge, no service engine light on.  To confirm this, I disconnected the IACV (idle air control valve) and the truck idles perfect, hook it back up and it goes back to surging.  I ordered the IACV valve, but now the service engine light remains on even with it connected back up.  I tried to disconnect the battery for 10 minutes but the service engine light is still on and the IACV is connected back up.  I have not installed the new IACV yet (will do it this weekend), but I am trying to find out how to reset the check engine light once I have the new IACV installed.
Anyone have any ideas?  I really dont want to take it to a shop and have them charge me $100 to reset this light.
Thanks... 01 Frontier
Back to Top View 01Frontier's Profile Search for other posts by 01Frontier
davidjbrady
Posted: Jun 12 2009 at 9:03am | IP Logged Quote davidjbrady
I used to have a 94 pathfinder, and could reset the engine light by the ECM, located under the passeneger seat. I would turn it to position 4, and then back to 1 to reset it, but this was OBD 1 program, I believe anything 95 and newer uses OBDII. I thought the only way to turn off the light was to have it reset by the scanner tool, I did hear you can go to Auto zone and they will loan you ( for free) the OBDII scanner to reset your codes.
David
08 Frontier CC, 4X4, LWB
Boomer
Posted: Jun 12 2009 at 3:55pm | IP Logged Quote Boomer
Auto Zone here in PA will NOT turn off codes, only read them.  Either find an OBD-II reader that does it and get access to it or go to the dealer.  The latter is $$$.  Sometimes they charge enough, you could buy a scanner that turns off codes for the same price.
2007 Nissan Frontier SE 4X4
Posted: Jun 23 2009 at 8:41pm | IP Logged Quote frontierguy
Once the malfunction is corrected the SES will go out after so many key cycles(trips).
surfahjammer
U.S. - Hawaii
Posted: Jul 13 2009 at 4:59am | IP Logged Quote surfahjammer
Could be just air in your fuel line that's causing the light to go on.  I think once you install the new IACV it'll go off.  Also check your gas cap turn it until you hear at least 5 or 6 clicks.  Something as simple as a loose gas cap can trigger the light to go on.  Good luck!
live to surf:) surf to live
Back to Top View surfahjammer's Profile Search for other posts by surfahjammer
