| Posted: Jun 16 2009 at 2:17pm | IP Logged
the bottom adjustment is the only adjustment. If it's the correct belt, and that far out, then you might want to try getting a smaller one. Take the old one off and go down to a parts store and tell them what's going on. If you have a decent parts guy they'll take the old one in the back and compare them side by side.
Now did you do the replacing or did you pay a shop? Shops can be shady and will claim they have done the work and not touch a thing. They might not have even replaced the belt at all but only adjusted it out.
Being that mechanic, I can tell you that some of the sprays work. But if it's squeeling, it's a sign something is wrong. Be it a belt that has stretched some (normal), or a worn belt that needs replacing. And putting spray onto a belt that needs replacing is just asking for it to snap on you while out in the middle of no where.
