Subject Topic: broken snap ring seal Post ReplyPost New Topic
jbradford
Posted: Jul 23 2009 at 11:53am | IP Logged Quote jbradford
i broke the plastic piece on the ring snap in the free running hub on my 2000 frontier 4X4 V6. i can put the ring snap back on with out the plastic piece but can i drive without the plastic piece on there? Really need help on this because i am borrowing a car right now until i get confirmation on if i can drive my own truck with out this piece or not.
Back to Top View jbradford's Profile Search for other posts by jbradford
Posted: Jul 23 2009 at 2:52pm | IP Logged Quote lakota
Im only guessing!  If the wheel rotates without the half shaft rotating and it sounds ok it might not do any damage. Check for for over heating in the hub. If it's hotter than the other side in a mile or three it is not a good sign!
If the wheel falls off... it may not be a good sign! Stop and pick it up...
Remember,  Im only guessing! Someone alse might know.
Help save the 2nd Amendment & Freedom. > Join Free:
http://www.nrahq.org/nrabonus/accept-membership.asp
jbradford
Posted: Jul 23 2009 at 9:35pm | IP Logged Quote jbradford
so this shouldnt be a big deal for now??? i know you're guessing but the only thing that this plasitc piece looks like it does it keep the spring in a more round shape.
Posted: Jul 27 2009 at 9:13pm | IP Logged Quote frontierguy
In all honesty it sounds like you are in over your head and should take it to a competent shop.
