Subject Topic: coolant leak,and hard steering Post ReplyPost New Topic
bryanwv14
U.S. - Virginia
Posted: Jul 29 2009 at 6:46pm | IP Logged Quote bryanwv14
i know they arent related,but my 03 with only 34000 miles has both problems,coolant leak. looks to be water pump,or thermostat gasket related...hard to see without tearing down.steering is hard in spots at times,more when below 40 degrees f.like when the fluid is thick,but only in spots..thanks for any and all replies,live in va,so not alot of salt or really cold...almost paid off and fallin apart...not to mention the front suspension,needs stronger shocks..and the 7 times i had it at the dealer while under warranty,,,wtf please help
Back to Top View bryanwv14's Profile Search for other posts by bryanwv14
bryanwv14
U.S. - Virginia
Posted: Jul 29 2009 at 6:52pm | IP Logged Quote bryanwv14
also ac compressor very loud,when enguaging the clutch...i bought it new in 03 with 13 miles,now have 34000 miles...
Posted: Jul 29 2009 at 8:17pm | IP Logged Quote frontierguy
Check with your dealer, maybe you can get some "goodwill" warranty even though you are out in time. My warranty clerk says that we can do "goodwill claims" up to $300 per complaint?????
bryanwv14
U.S. - Virginia
Posted: Jul 30 2009 at 5:17am | IP Logged Quote bryanwv14
thanks,ill try it
