Subject Topic: Sensor issues with 02 frontier Post ReplyPost New Topic
mocheeks77
Posted: Aug 06 2009 at 10:37am | IP Logged Quote mocheeks77
I have been having an issue with my 02 frontier (4 cyl). When  I press the brake pedal all the way to the floor, my ABS light and parking brake light come on. If I only press the brake gently, this doesnt happen. Has anyone had this problem before or have any suggestions? When I turn the ignition off and start the truck back up, the lights are off, but as soon as I press the breake hard , they come back. Thanks for any advice.
Back to Top View mocheeks77's Profile Search for other posts by mocheeks77
davidjbrady
Posted: Aug 06 2009 at 2:25pm | IP Logged Quote davidjbrady
Any chance your brake fluid is low?
David
08 Frontier CC, 4X4, LWB
mocheeks77
Posted: Aug 06 2009 at 5:02pm | IP Logged Quote mocheeks77
Fluid levels are fine, I'm guessing its a faulty sensor but I was trying to avoid taking it in for service. I was hoping someone on here would have had the same problem and could give me a heads up.
Posted: Aug 07 2009 at 8:19pm | IP Logged Quote frontierguy
double check your fluid just to be sure. have you checked for trouble codes?
mocheeks77
Posted: Aug 08 2009 at 9:23am | IP Logged Quote mocheeks77
Levels still look fine, but I dont have a diagnostic scanner. Thanks for the suggestions
